insulating a garage
  • doncook7
    • 24
    • Berkley, MI. (just a few miles north of detroit)
    insulating a garage
    I have a one car, unattached garage. I am currently in the process of turning it into my workshop, where I will work SOME of the time in the cold. (I live in Michigan). Assuming I won't be out there every hour, every day; and heat will be supplied by a small space heater....My questions are:
    1. What r-value should I use? Styrofoam? Fiberglass?
    2. What type of cheap space heater? Electric? Torpedo (kerosene)?
    Remember, I will not be living in this, just working there now and then.
    As you can probably tell, I'm trying to do this in a miserly fashion... (cheap)
    Thank you for any thoughts/or comments.
    don
  • bigstick509
    • 1227
    • Macomb, MI, USA.
    Welcome
    My fellow Michigander, IMO put in as much insulation as you can afford,and I use a propane heater in my garage/shop.
      Ditto what Mike said. I bought a propane heater 50,000-200,000 BTU at Menard's along with a 100 pound propane tank. Works great and even spending a lot of time in my garage shop I only used 1 tank of propane last winter here in NW Indiana.
      • Russianwolf
        • 3152
        • Martinsburg, WV, USA.
        • One of them there Toy saws
        propane torpedo......
        I the inside already finished or bare studs? If studs, the easiest is to usee fiberglass. If finished cellulose blown in.
        Lakota's Dad
        • doncook7
          • 24
          Thanks!
          Thank you both for a speedy response and some great information. Hadn't even thought about the propane route.
          Thanks again!
          Don
