Gack! Rockler DC hoses/fittings + Ridgid vac
  • wreckwriter
    • 449
    • South Florida
    all my hoses and fittings came in today; unfortunately none of them, including the "shop vac adapter" will fit on my vac, fittings on vac are just a skosh too big. Vac is a Ridgid 2 hp, 6 gallon model, hoses and fittings are 2.5 inch.
    Does anyone know where I can get an adapter to make this work or what brand vac I can buy that will fit?
    http://www.wreckwriter.com/
    I found a $20 Rigid kit at the BORG. It has a length of hose and a few connectors. You might be able to use one of the connectors to terminate your Rockler hose - maybe.
    HTH,
    • wreckwriter
      • 449
      • South Florida
      HTH,
      heh, yea, maybe
      Thanks!
      • preamble
        • 24
        • Pittburgh, PA, USA.
        Rockler or Woodcraft should have the adapter that you seek.
        • JTimmons
          • 690
          • Denver, CO.
          I'm not sure where you are exactly in Florida, but you might want to give Woodcraft a try. Looks like they got 4 stores in Florida.
          http://www.woodcraft.com/stores/Defa...state&state=FL
          Here's a link to the DC stuff they have on-line.
          http://www.woodcraft.com/depts.aspx?pd=2170&deptid=2170
          -- Johnny Carson
          • wreckwriter
            • 449
            • South Florida
            Thanks for the replies guys. I was painting my porch all weekend so haven't had time to do much on this yet.
            The fittings ALMOST fit, it seems most of the problem is 4 little raised areas inside the adapter. I'm thinking dremel tool at this point, just need to make sure I don't make something not fit by making something fit....
            Anyone know what the hose size difference is between Shop Vac units and Ridgid? My Ridgid is pretty old too....
            • davehenry
              • 46
              • Slidell, LA, USA.
              Look at Lee Valley for part number 03J61.15
              http://www.leevalley.com/wood/page.a...,45029&p=45029
              This item has saved me a lot of headaches.
              dave
              "I can't be unhinged -- I already installed them!"
              • wreckwriter
                • 449
                • South Florida
                dave
                Yep, that's what I need! Ordered. Thanks very much!
