Talking to a friend about setting my Rigid vac (6 gal) up as a DC system; he says I need some sort of bag around the filter or it will clog constantly. Is he right?
Dust collection with shop vac
Tags: None
I have a 12 gal. Rigid and yes, the filter clogs up after a while. I've heard that an old nylon stocking or panty hose pulled over the filter will keep a lot of the junk out of it. The bag will work also, but will probably cut down the airflow somewhat. I've gotten resigned to knocking and brushing out the filter folds when needed; Last time, I washed it with a hose, which pretty much restored it to like-new condition.
I think you're going to find that a 6-gallon vac is too small to be a good DC; although we all have to do with what we have
. Even a large shop vac can't keep up with the volume of chips and dust from a planer or joiner.
Gary J. Bivin
Gilbert, AZ -
I tried to find the thread where I described the bag, but I don't have much time to search, being at work. Short answer: If you use a bag, life is soooo much better and you will have a good suction for longer. Otherwise, you have to keep stopping the shop vac to clean out the filter.Joe SacherComment
Thanks for the reply. So far the only use will be for my 3100, one hose to the main port and Y to the Shark Guard, blast gate on lower hose so I can swap from Shark to router attachment. I'm thinking it will keep up with this.Comment
Shop vac makes a foam cover for there filters and these will also fit some of the filters used by other vendors.Comment
I've been using that vac with my BT since I bought it. I also use it with my router table. You pretty much need to clean out the filter every time you dump the vac out. And that is much sooner than you will want to with the small vac. The bag isn't needed, but I've been thinking of trying to find one.Originally posted by wreckwriterTalking to a friend about setting my Rigid vac (6 gal) up as a DC system; he says I need some sort of bag around the filter or it will clog constantly. Is he right?
I also reccommend replacing the filter with the HEPA filter that they sell. That way you filter out the harmful fine dust.
It definately does not seem to be a premanent solution, but is better than no dust collection.
-JimComment
I've gone through three bags with my shopvac (6.5 A 12 or 16 Gal) and I haven't had to clean the filter at all. The only time I had to clean the filter is from when I ran it without a bag. After that, no more. It is worth the $3 a bag for the lack of work and clean emptying.Joe SacherComment
You using standard bags made by shopvac or something specific?Originally posted by sacherjjI've gone through three bags with my shopvac (6.5 A 12 or 16 Gal) and I haven't had to clean the filter at all. The only time I had to clean the filter is from when I ran it without a bag. After that, no more. It is worth the $3 a bag for the lack of work and clean emptying.Comment
I have two filters for my 12 gal Ridgid. Filters are washable, so when one clogs up, I open up the vac, swap the filter, and then vacuum the dust off the dirty filter. Then wash the filter, let it dry off, and set aside until I need to swap it in.
I tossed the original filter - I have two of their 1-micron filters.Comment
My filter appears to be paper, I wouldn't think washable. I've been using the cheapie general purpose filters up to now, just using it as a vacuum. Now with this new use I'll recheck options.Originally posted by scorrpioI have two filters for my 12 gal Ridgid. Filters are washable, so when one clogs up, I open up the vac, swap the filter, and then vacuum the dust off the dirty filter. Then wash the filter, let it dry off, and set aside until I need to swap it in.
You need to look for "CleanStream" Filters. They are sold at Sears, and at Lowe's I know. HD sells the bags , and you can just use the one that is made for the 4 Gallon Vac i'm sure. The CleanStream filters are HEPA and run about $30. Sears has them on clearance right now if you can find one to fit. Also, the Lowe's sells a CleanStream that will fit Ridgid models also. Mattter of fact, it says it right on the box in red background, "Fits Ridgid and Shop-vac models."Comment
Picked up a Ridgid compatible Cleanstream at Sears for $8 last week. Had to dig to find it. Just look for the red markings on the box. It doesn't specifically say Ridgid, but it fits fine. Everything else was black.
I've been doing a lot with MDF lately, and the Cleanstream did ok compared to the regualr filter. Plugged as quickly as the stock, but cleaned out much quicker/easier/better. I did not have a bag on the filter. Maybe thats something I should look into. Anyway, definately worth the $8, probably not the $30.Comment
Something else you may consider that I had hooked up to my Rigid 12 gal. is one of these:
http://www.harborfreight.com/cpi/cta...temnumber=9586
I got mine at Woodcraft and paid twice as much for it, but it worked quite well along with a foam filter."Happiness is your dentist telling you it won't hurt and then having him catch his hand in the drill."
-- Johnny CarsonComment
Interesting. That goes in line between vac and dust hose?Originally posted by JTimmonsSomething else you may consider that I had hooked up to my Rigid 12 gal. is one of these:
I got mine at Woodcraft and paid twice as much for it, but it worked quite well along with a foam filter.Comment
