I need to get some lumber off the garage floor and reclaim some of the space. I was thinking of building a lumber rack similar to Boyd's photo in the following thread:
http://bt3central.com/showthread.php...ht=lumber+rack
I estimate my cost for lumber, bolts, and pipes to be about $30. However, Amazon sells a Triton Lumber Rack for $60.
To distribute the load of the lumber, I was planning to use three or four 2x4 for the vertical support. The Triton system uses two (metal coated) vertical supports.
Should I build it myself or just buy it?
________
Club Royal Condo Pattaya
________
With just 2 vertical supports I'd wonder about bowing of stored lumber. The pipes in my rack are 24" apart. If you build don't forget to drill the pipe holes at a slight angle. The white pipe covering is to keep the black pipe or galvanized pipe from staining the lumber.
