Back in August I took apart the shop when I had movers come a pick up all my stuff. When I disassembled the DC I noted a couple of things I thought I would pass along. First off I have the 2HP HF DC with the Wynn filter (Donut conversion), and the neutral vane modification. I removed the 5->4 Y adapter on the intake and replaced it with a 6->5 inch metal HVAC reducer and ran all 6” HVAC ducting with drop down 4” hoses. I had 2 4” hoses to the DC. 1 under the saw and 1 into the dust port. Plus a 2 ˝ line to the shark guard.
This may have been a little too much piping to the BT3K, when I took apart my piping the overhead horizontal run between the Saw and the DC had about a ˝” of saw dust resting in the bottom. With all the runs to the saw and the 6” ducting I think my airspeed was too slow to pull all the dust to the DC.
When I took my filter off to prepare it for travel there was a lot of dust stuck inside the pleating. This model filter has diamond pattern metal screen around both the inside and the outside of the filter. I tried using my air compressor to clean it and that worked ok, but I found shaking it against the ground and putting the end of the leaf blower against the outside metal screen and then down the inside worked the best to get it clean.
And one more note, do not I repeat DO NOT attempt to clean the filter this way in you driveway with your wife’s black car parked nearby, especially if the windows are DOWN[B)]
Sounds like something I would do.
