Ok I got a Tradsman Drill press and I am building a stand on a budget. Bought $20 in wood. Mostly off Damaged section. Anyway 2 foot deap, 2 foot tall, and 3 foot wide is it's size. I bought a 4x6 sheet of partical board $4.01 to use as the top and shelf 5/8 in. I am considering doubling it up and using 2 layers on the top. Would this be a good idea? The frame is built out of 2x4's and a couple 2x2's It seams super sturdy and I still need to add a couple braces but I am 100% happy so far. I got a sheet of 1/4" decorative type plywood for the sides also $4.01 just had a ding in the front.
Drill Press Stand On a Budget (FINISHED)
I would definately double the top thickness.Monte (another darksider)
http://community.webshots.com/user/monte49002Comment
I have face glued MDF for several projects. PB should work about the same. Coat both surfaces with glue and use plenty of clamoing pressure. Use cauls to make sure the center of the panel gets pressure.
Another trick is to pull them together with coarse drywall screws from the underside. Plan ahead if you do this so the screws won't be where you have to drill the mounting holes later. Get the screws tight but be careful not to strip them out.Don, aka Pappy,
PlatoComment
I have the ryobi 10" DP, it's a heavy one also. I build a little mobile cabinet for under it, nothing fancy. I used 2x4 construction, made the side frames by double biscuiting, then screwed the top and bottom supports into place, sheathed everything with some left over cabinet 3/4 ply I had. I did put an extra 2x4 across the center where the DP sits, no noticable deflection, it's held up well.
dunno if that helps at all, but sneaking a 2x right under where the dp sits should provide ample support.
Go Steelers!Comment
Not alot to look at but this is the basic frame. Remember I am new at this stuff. Also looking for sugestions on what to do with the Partical board. Paint or no paint? Spray can fine? Black? Base is going to be white as I have a can of it already Gloss White Exterior Paint. Also remember im covering it with 1/4" decorative type plywood.
Well I see a frame that would hold up a truck with or without a doubled top
. The benefit of doubling the top would be giving you some meat to bolt the press to.
The particle board I`ve been seing at the Borgs is far better stuff than we bought 20-30 yrs ago. Much finer particles and more uniform.
I think sanding priming and painting should work fine. If you have enough white paint that would be my choice. I would not pick a dark color because you are bound to lay drill bits and small items on the top and with a dark background they will be harder to see.
At least they would to my 50 something eyes and bifocals.
Sanity is just a one trick pony. Being a bit Crazy is a wide open field of opportunity!Comment
Hi JonBoy;
That frame is way overkill for a table drill press, but better safe than sorry. If you cover that over with plywood, even the thin stuff you are using, it will be plenty solid and stiff. Double the thickness of the top material, glued up and yes, you can use sheet rock screws and remove them later for the glue up on the top, and you can use the cabinet/stand as a base to put the jack under the main beam to level your house
That is if you use the heavy duty wheels under it of course
(Just Kidding... don't really try that!!!)
Nice work by the way...your shop is going to be nice
WEGComment
Overkill Weg?
Hey 2x4's are cheap and I just started putting it together as I went no real plan. I bought a 10" GMC drill press at first and it wasnt to heavy 50-60 lbs that would have worked fine on my bench. It didnt turn out to well and I sugest against GMC tools now. Anyway the 12" tradesman drill press it heavy 100lbs or more it seems. Also about not painting the top black thanks. I never thought about drills setting up there. Also I did glue the top together. Its in the background.Comment
Hi JonBoy;
Not in a bad way JonBoy. I certainly didn't mean overkill pricewise. It will be a great cabinet that you can use for just about any tool you will eventually buy. From the looks of the framing, it really will be a very sturdy cabinet. More than adequate for your bench top Tradesman drill press. And welcome to the forum.
WEGComment
JonBoy,
Thanks for posting the pic. I've been working over ideas in my head for something to put my DP on and have room for storage underneath. You pic gives me another idea to consider.
"Success is gettin' what you want; Happiness is wantin' what you get." - Brother Dave Gardner (1926-1983)Comment
Well, if you have a camera take a picture of what you do. I just bought some stuff after seeing some usable stuff on the HD damaged section of wood. Looked at it as a jig saw puzzle and started putting 2x4 together until I had something sturdy looking. Should get a little more done today. Also just upgraded from a bst15 to a bt3. And I never belive that it would be that much better but it is.Comment
Well, got to work on it today some. Still need to round over the top, mount the top, add back, and make 2 doors. All and all including wood, hardware, screws, and, nails should be under $30 painting white because its FREE. I think it will turn out just fine.
