lrogers.This is a 16x24 like you are wanting to do. I live in southern Ill weather can get bad here, thats where I got my wood to build with.
24 logs to 3 different mills. I built it off the gound on 12
6x6 treated post with 2x8 floor joists, 3/4" plywood subfloor (insulated with blown in fiberglass) you cant get the insulation to burn with a torch on it, anyway, wall's are all 11 1/2' to sill plate, 24" centers all out of rough cut 2x6 white and red oak. There are 2 floors, 2nd floor in center has 6' clearnce (upstairs is all storage) bottom floor is 8' ceiling with exposed rafters. covered all wall's with 1/2" plywood, painted to a with gloss finish. used 9 2 bulb 4 ft
flourscent on lower floor and 3 in upsatirs, all lights plug in.
2 switch'es 1 for upsatir's one for down, ran power down middle
of ceiling on 1st floor, used 4plug outlets (1 spair slot each)
each long wall has 6 4outlet plugs all at about 4' off the floor
back & front wall has four outlets. So far I havent had to trip
over any cords. Oh I finished the floor with armstrong tile
the commercial type that is 1/8" thick (couldnt find a flat white
this has somr grey specks in it). If I had to buy the lumber I have
estimated it to be 11thou plus. Dont ask about a plan, it came out
of my builder's head. I told him what I want'ed & he built it
in about 3 days. I would have built it but a lot of the 2x6's
were to heavy for me to do anything with. Everything is 2x6 or bigger
and all insulated. should be able to heat it with my table saw's
motor heat[
motor heat[
