Question about raised panel cabinet?
  • ronmetz
    • Oct 2003
    • 29
    • wilmington, nc, USA.
    I am building new kitchen cabinets which will be four lower units. One of these will show on the end .. so I doing a double raised panel. The question I have is concerning the middle style. Should this be glued in the center on the coped ends or should it just be free to move like the panels?
    thanks
    Ron
  • JSUPreston
    • 1189
    • Montgomery, AL.
    I would think gluing just the middle 3rd of the stile would be fine. It would allow for movement, as long as the panels are floating.
      I do not think that you need to worry about movement in a stile. I would glue it.
      • Carpenter96
        • Aug 2011
        • 178
        • Barrie ON Canada
        • BT 3000
        Plus one on gluing the stile. We had all sorts of this situation when I restored wooden boats glue stile and let your panels float. If wood is going to move a lot it would be in a wooden boat and we never had a problem.
        Regards Bob
