I've been wanting to upgrade to my final saw, but with my budget and the amount of time I have to devote to woodworking it's not really appropriate right now. So I'm sticking with my old C-man 80's contractor saw on the custom base I built.
It took two years, but I finally have the saw and the base moved from my old shop in the basement to the garage of my new house. Currently, the saw's in pieces, so I'm taking the opportunity to refurb it, and I'll obviously need to re-calibrate it as well.
Tomorrow I should have the PALS system from In-Line industries, to help align the trunion and lock it in. I have a new ZCTP, since I'm guessing my old one will now be slightly off. I also got the micro jig splitter system a while ago when it was on sale, so I'll be adding that as well. And tomorrow I'm going to Woodcraft to pick up some UHMW to re-face my old Beise fence (the original ply faces were warped from too much moisture).
In addition to all that, I'm building a new top extention that will double of a workspace, router table, and multi-function table to mount my other tools to (OSS, DP, Grinder, Buffer, Belt Sander). To that end, I bought a $10 piece of laminate for the top, and had a sheet of 3/4" MDF cut to size. The laminate isn't the exact type I wanted- I remember a thread about the laminate with the least amount of friction- but that would be something I'd need to buy in a large sheet from the distributor for $100 or so. Anyway, I'm planning on laminating 2 or 3 pieces of the MDF, then the laminate. Obviously contact cement is what you use for the laminate, but for speed's sake, I'm wondering if using that to laminate the 2 or 3 layers of MDF to each other would also work.
I'm excited to finally get my saw into my shop- and improved to boot.
Thanks!
Thanks!
