forstner bit on plastics?
  • Stytooner
    Roll Tide RIP Lee
    • 4301
    • Robertsdale, AL, USA.
    The specialty bits attempt to keep acrylic from cracking after being drilled.
    The little acrylic I have used has had mixed results with those bits.
    I don't see any cracking worth mentioning in polycarbonate. When it does, it is thinner stuff and the bit caught and pulled or jerked through.
      I will add that for me, Forstners did fine with lexan but other plastics/acrylics did not always do as well. Lexan was like cutting hard butter, and I got ribbons; But plastics/acrylics varied from rough to cracking. On most plastics/acrylics, I used a hole saw.
        I've also used hole saws with acceptable results, Although I use the same methods, I can feel the difference between machining cast acrylic, extruded acrylic, and polycarbonate. What's a real PITA, is machining 1¼" bullet rated material. I had a few bank projects to do teller windows and drive through enclosures.
