A couple of years ago I went dumpster diving and got a lot of mahogany from a desk that was being thrown away. I had been busted up, but I managed to get a good bit of useable material. Had I been a few minutes earlier, I wouldn't have the problem I've run into.
SWMBO and I decided that we want a square coffee table. I sketched up quite a few different ideas on paper (still haven't learned SketchUp), and we came up with a design that we both like. A quick look at mahogany inventory, and I thought I had enough. So, I started building. To make the long story short, I need a couple of pieced of mahogany plywood, and I've had no luck finding any in Montgomery, AL. I've called several different places, and other than ordering from the BORG, I'm looking at 2 to 3 weeks before a lumber supplier will have some in stock.
I'm pretty sure that what I have is Honduran Mahogany (like I said, OLD desk). Do you guys have a recommendation on a substitute that would have a similar grain pattern? The whole thing will be stained to match existing living room furniture. So, color isn't quite as big an issue, although the closer to mahogany it is, the less work I'll have.
