I have to build doors to some book shelves that I had built long ago. I was thinking of doing it frame-and-panel, with hardwood frame and plywood panel, something like this :
I have some thin ply - thicker than 1/8 but not quite 1/4" (checked just now - measures 5.3mm or 0.2"), with one good side. I thought of covering the other side with some good looking laminate I already own - with the additional benefit of stiffening up the panel.
That made me think - I might as well glue laminate to both sides for consistency of looks; and of course that begs the question - if I have to apply laminate to both sides, can I just use hardboard for the middle instead of the thin ply? Have some unused hardboard lying around.
I know the strength might be reduced, but this is just some book-shelf door inside the house; will I need to worry about moisture problems? I might have to pay attention to adhesion too - hardboard backs are not too good with glue.
