How Would You Make This?
    http://officemagz.com/original-woode...d-johnson.html
    I wouldn't. Not my personal taste.
    Looks like Photoshop to me and that description reads like a MadLib.
      Its a very interesting project! Its out of my league, but I would think that the rails and stiles where created by bandsawing from larger stock then ripping. Off-setting the curves gives it a more natural and non-repeating flow. The author mentions laminating, so I imagine the door panels where made in a form with plies laid up and glued over "bumps". Just my opinion. :-)
        Hers's a better image...
          • 8807
          Paul hit on it - via photoshop!
          One of a kind - for the purpose of being "one of a kind" doesn't get me excited. Aesthetics should play part of the role.
            You don't have to like it, and don't have to make it. But, in the custom end of woodworking, we are presented with this type of challenge (not this one in particular). I don't have to like it to make it, but it's a matter of making a living or not.
            • Stytooner
              Roll Tide RIP Lee
              • 4301
              • Robertsdale, AL, USA.
              Looks like it was designed by sketching fast on a napkin. Then carried out realistically.
              I think it is both challenging and cool looking. I'd absolutely give it a shot if I had the time. Imagine all the furniture in a house done in a similar fashion.
              If you are tired of doing straight lines or traditional designs, there are always other avenues to venture down.
              You guys remember Dave down under? He traveled his own path for sure.
              To make it I think there would be lots of laminating as has been mentioned.
              • jking
                • 972
                • Des Moines, IA.
                I would build it square, then put it in a tank of water for a while, pull it out & let it warp on its own.
                • sailor55330
                  • Jan 2010
                  • 494
                  build it straight and drink heavily
                    Been a long day, and I am sitting here having a long talk with my psychologist, W. L. Weller.
                    Are you saying that dresser isn't straight?
                    • Sweet Willy
                      • May 2011
                      • 195
                      • Near Chattanooga, TN
                      • ridgid 3650
                      Most of my stuff turns out looking like that. What's the big deal?
                      Dennis
                      Sweet Willy
                      sigpic
                        Band saw box.
                        • ivwshane
                          • 446
                          • Sacramento CA
                          Is it possible to do vacuum forming with layers of veneer sheets?
                            Absolutely, that is what I mentioned earlier on. --> "door panels where made in a form with plies laid up and glued over "bumps"."
                            Form could be clamped or vacuum clamped, no difference in end result. Vacuum bag if big enough would be faster than setting up all the cauls necessary to do something like that... if it is real
                              I have my doubts that it was done that way. Even with the veneer soaking wet, it doesn't seem likely that it would fit the biases (that much contour).
