Help with Finishing
  • Bruce Cohen
    • 2698
    • Nanuet, NY, USA.
    Help with Finishing
    I'm about finishing up an Asian style jewelry box.
    The woods are Bloodwood and Gabon Ebony. Usually I don't like a glossy finish, but this project seems to scream out for it. The Bloodwood which constitutes about 80% of the box has already been finished with my usual 3 coats of Watco natural Danish oil finish. The Ebony has been sanded up to 600 grit and then polished on a rag wheel with White Rouge.
    What I would want to do is to final coat the box with, hopefully, a wipe on gloss varnish or shellac. Having never used any finish other than Watco, I can't seem to find an answer anywhere.
    I figured that one of you guys must have the answer.
    All responses will be gladly appreciated.
    Many thanks,
    Bruce
    Samuel Colt did"
    I use about a 1 1/2 lb cut Shellac to finish the totes and knobs on planes. 3-4 thin wipe on coats leaves a great high gloss finish. I use a grey sunthetic pad to rough the surface between coats.
