I seriously debated buying this on the spot Saturday. If they still have it and you say it can be done, it will be mine.
I've been wanting to replace the doors on my shop, they are simple plywood 'doors.' Standard height, not a standard width. I found a set of exterior French doors that fit what my design wants to be perfectly, but they are a combined 12.5" too wide. I was wondering if it were feasible to rip the door about 6" on the hinge side in order to get them to fit. They appear to be solid core doors. This is such a good deal that the total cost would be way less than materials to build inferior versions from scratch.
I know absolutely nothing about door construction. I don't know if what I am suggesting is worth it. I would open the door frame up to fit, but that's a whole 'nother adventure I'm not sure I want to explore.
). One of the doors needed about 3' cut off to make it fit. When I cut it, I realized that the core of the door was glued up chips and sawdust that literally crumbled in my hands. It worked for my purpose.
