Hi,
I'm finishing up a bandsaw stand I built and am in the process of finishing it. I used birch plywood for the construction (wish I had used oak in retrospect). I have applied 2 coats of Minwax wipe on poly so far, sanding with 220 after the first and fine steel wool after the second. I really haven't seen much difference between the 1st and 2nd coats. Given that this is built for the shop, does anyone have any advice for adding a 3rd coat? I'm leaning towards it for added durability (or am I just spinning my wheels).
Thank you.
Thank you.
