I am in the process of veneering (10 mil paperbacked Oak veneer) to an mdf substrate using contact cement. I have been "cautioned" (from a veneer tutorial on a website I visit) on using an oil based finish as it "might" soak thru the veneer and backing and dissolve the contact cement.
I had planned on using a min-wax poly clearcoat finish (no staining or dyeing) and cutting it with mineral spirits then wiping it on--5 or 6 coats with a light sanding in between each app.
I did this exact finishing technique (same type of oak veneer on mdf with same poly I plan to use) two years ago and really liked the outcome (thanks to input from several members on this forum--thx guys). The difference between that project and this one is: This project I am actually doing the veneering myself. The other project, I bought "oak-veneered mdf". If this is a legitimate concern (I assume it is), then might anyone have a "workaround" suggestion?
It is for indoor use only and will be gifted when I am finally finished with it.
thx, for any help/suggestions.
