I'm about to build several bookcases for our basement (Birch ply with maple face frames). I'm thinking about spraying the pieces with shellac, then wipe on poly, then cutting the dados and shelf pin holes.
I'm wondering if this is a good procedure, or should I wait until the carcass is together before spraying?
Also, any tips for making the pin holes blend with the finish? The raw wood inside the hole drives me crazy. I'm wondering if I dab the holes with shellac if the pins will still fit.
Thanks!
g.
Thanks!
g.
