How to glue/fasten vinyl poster to wood?
  • bruffc
    • 149
    • Gardner, KS, USA.
    • BT3
    I'm looking for suggestions on how to mount/fasten/glue a vinyl poster to wood (pro'lly Luan as I have some on hand). This is for my garage wall so it's nothing fancy.
    I tired spray adhesive to thick corrugated cardboard prior and it didn't work. I don't know if the poster is to heavy because it's vinyl or maybe it was the cardboard.
    Should I try the spray adhesive again but this time with the plywood? Is there something else someone could recommend (double sided tape, etc)? Or is there a type of resin I could use?
    Thanks
    Bryan
    If your spray adhesive is a contact cement, which requires both surfaces to be coated...dry time, stick together, it should have worked. If not, use a regular solvent base contact cement.
    • Mr__Bill
      • 2096
      • Tacoma, WA
      I would use vinyl wallpaper past.
      • bruffc
        • 149
        • Gardner, KS, USA.
        • BT3
        Would this work against wood or just drywall surfaces?
        Bryan
        • bruffc
          • 149
          • Gardner, KS, USA.
          • BT3
          My previous effort.....
          was with 3M Super 77 Multipurpose Adhesive. I still have some of this left, should I try it again except using plywood instead of cardboard?
          Thanks
          Bryan
          • Tom Slick
            • 2913
            • Paso Robles, Calif, USA.
            • sears BT3 clone
            Did you allow the spray adhesive to dry 5-10 mins before attaching the two pieces. If it's still wet the pieces won't bond.
