Solving A Silicone Problem
    I got visited by an old friend cabinetmaker that ran into a problem. He made some commercial showcases for a jewelry store. They are black high gloss mica (like Formica), and the glass is set in to a rabbet with a bead of silicone (GE Silicone II).
    The problem he has is that during the process, there is squeeze out and smears of silicone on the mica surfaces that he can't get off. He said he tried every chemical he could get his hands on to dissolve the silicone, but nothing worked. Chemicals like lacquer thinner, acetone, MEK, different alcohols, toluene, xylene, mineral spirits, turpentine, kerosene, and even a heat gun didn't work. He said he tried scraping it off, but left visible scratches. There is too much to rub off.
    I told him I know that problem as I've had that happen. My solution was to carefully smear Vaseline on the mica prior to laying the bead. Doing that, a sharp single edged razor blade along the glass would cut a clean line, and all the rest would just pull off. That advice is a little late now.
    I'm not knocking silicone, as it's great for bedding glass and assembling aquariums. So, the question is what chemical if any will dissolve cured silicone?
  • herb fellows
    • New York City
    from the horses mouth, so to speak:
    The GE silicone website is supposed to have info on this.
    • Stytooner
      Roll Tide RIP Lee
      • 4301
      • Robertsdale, AL, USA.
      http://www.rpm-technology.com/?gclid...FYdb2godLHIw5w
        Thanks. I'll send it on. I'd like to see that stuff dissolve silicone.
        • herb fellows
          • New York City
          $19 + shipping for 6 ozs? $100 + for a gallon? Maybe you want to find out how much of this you'll need.
            I don't need any of it. I learned my lesson a long time ago with prepping with Vaseline. Works good on finished woodwork too.
            • sparkeyjames
              • 1087
              • Redford MI.
              Vaseline and Silicone. I'm not sure I like where this thread is heading.
              • jabe
                • 582
                • Hilo, Hawaii
                cman, let us know which product your friend used and if it was successful. I had an uncle who was a glassier, and he used masking tape on the surfaces that he didn't want the silicone on. Wiped in the bead with a finger or rag dipped in paint thinner, then remove the masking tape, it left a nice clean edge. He made a lot of aquariums, his son raised exotic fishes.
                • Mr__Bill
                  • 2096
                  • Tacoma, WA
                  I haven't used it, but hanging on the hook in the paint department of my local ACE is a product that claims to remove the stuff so you can paint. It might be worth a look.
                    Are you thinking of "Goof-Off"?
                    • Mr__Bill
                      • 2096
                      • Tacoma, WA
                      Nope, this stuff was in a tube, like toothpaste, that had a label claiming it was Silicone Remover.
                      If I make it to ACE today I'll take another look.
                        Is this it?
                        • os1kne
                          • 901
                          • Atlanta, GA
                          Thanks for the vaseline idea.
                            I'm just waiting for the thread "Solving a Vaseline Problem"
                              That's easy. Didn't you see The Flamingo Kid...wipe on...wipe off.
