What wood for exterior windows?
  • dkerfoot
    • 1094
    • Holland, Michigan
    I have a 90 something year old home and am on a mission to restore and make functional my old wooden windows. Mostly this means lots of stripping and some minor repairs before painting/finishing.
    I have a set of three exterior storm windows that need to be completely replaced because the wood is deteriorated beyond repair. They are roughly 18" x 24" and are never operated or removed. They serve to protect and help insulate three leaded glass windows.
    My plan is to build new windows using my rail & stile router bit set. The question is, what wood should I use? They are going to be painted, so the prime considerations are cost, durability and BORGability.
    I happen to have some cedar leftover from another project, but I fear it would splinter like mad while routing.
    Whatcha think? What would you use?
    Doug Kerfoot
    KeyLlama.com
    I believe Marvin uses radiata pine for all of it's wood windows and doors, but they're aluminum clad on the exterior sides.
      In reality, if they are to be painted the species is relatively unimportant. Being BORGY is another thing. I don't know what they carry in your area. White Oak would be my first choice, but I doubt they carry that.
      They might have SYP, or Douglas Fir, either would work.
      • Mr__Bill
        • 2096
        • Tacoma, WA
        Most of the old wood storms that I have seen were 4/4 or 5/4 pine stock. Your choice may be limited to what you can get that is thick enough. Real Douglas Fir two-by may be the way to go and mill it to size. I would stay away from the hem-fir and mystery white wood.
        • dkerfoot
          • 1094
          • Holland, Michigan
          Looks like my BORGy options are:
          • Aspen
          • Red oak
          • Poplar
          • Eastern White Pine
          Douglas Fir is not available in this area.
          I am leaning towards the Poplar. Any reasons to avoid?
          Doug Kerfoot
          KeyLlama.com
            The poplar was my first choice in mind because of its smooth acceptance of paint. Others will chime in soon enough with their opinions, but I will say that since they will be painted, your primary concern, IMHO, would be machineability and surface prep prior to painting, in which poplar hands down is going to win. I would have to disagree somewhat with C-man on the pine or douglas fir since you will be sourcing them from the borg, you would have to wait a long time before they season, and even then, syp typically moves a little too much in my opinion to work well for a window frame. You can use them, but I think you have better options.
