I'm a little disappointed in my progress. I've been out and about this whole
weekend. Anyway, here's what's going on:
It was time to finish up the stretchers and runners. Since my dado was setup
already to cut the tongues on the ends of stretchers, I cut the tongues on
the sides of my runners.
Woops! Can you spot the goof? It won't affect the final build and I'm not
going to fix it.
As I said before, the stretchers span the case and will be notched into the
divider. I slipped the stretchers into their dadoes and marked the location of
the notch against the divider. I marked the notch location with a knife and
then gang cut the notch on my TS and miter gauge.
I placed the stretchers back in the dadoes and then cut spacers that matched
the opening height.
After that, I knifed the locations of the notches in my divider panel.
Over to the bandsaw to cut the notch.
Some cleanup required. Yeah, that's a sharp chisel.
The notches in the front and back of the divider panel are ready.
After cutting the runners to uniform length, a dry fit.
This afternoon I will try to route the mortises and fit the loose tenons. The
notches in the rear stretcher are cut deeper than the ones in the front. When
I assembled the web frame, the runners and the rear stretchers will not be
glued to the divider. This will let the divider and panel expand and contract
with the seasons.
Paul
going to fix it.
the opening height.
with the seasons.
Paul
