Just an FYI: if no one has used this plywood from the BORG yet.....GET SOME
The veneer is actually thick enough to be seen with the naked eye! The plywood is veneer core and is exceptionally stable, even after being cut. The veneer did not flake or separate after cutting. (to be fair i did use a zctp and an 80 tooth hatb blade, but the blade is getting dull as its about 4 years old) It runs $39.95 for 3/4" birch (one good side IMHO) so you actually get what you pay for.
This is the preliminary info I have on it. Over the next few weeks we will see what happens to it. I will let you know also on how it stains.
The veneer is actually thick enough to be seen with the naked eye! The plywood is veneer core and is exceptionally stable, even after being cut. The veneer did not flake or separate after cutting. (to be fair i did use a zctp and an 80 tooth hatb blade, but the blade is getting dull as its about 4 years old) It runs $39.95 for 3/4" birch (one good side IMHO) so you actually get what you pay for.This is the preliminary info I have on it. Over the next few weeks we will see what happens to it. I will let you know also on how it stains.
