Here's a few suggestions for their use in the shop.
Great for cleaning metal surfaces, as their material won't rust.
Great for finishing. They are available in several "grit equivalents", identifiable by their color.
They can be cut and applied directly to the sandpaper on a ROS or a finishing sander.
If you damage or need a replacement filter for the air compressor pump, they can be cut to fit.
Here is a chart with what's available.
