I am in the beginning stages of constructing some new upper cabinets for our kitchen and I have a question about what joinery method is best to use. In the past I have always used dados and glue to assemble a cabinet carcass, but I have begun to use pocket hole joinery more and more things. I have recently come across some simple cabinet making instructions that included both my old dado method for thje carcass assembly and the use of pocket holes for the face frame assembly with a glue up for the face frame to the carcass.
I wonder if using pocket hole joinery along with glue might be a stonger way to assemble the carcass (by the carcass I mean just the box itself and the joint I am refering to is the one that joins the base and top to the sides). I might be able to use both dadoes and pocket holes, but that might be overkill. The first upper cabinet I intend to build will be 8 ft long and almost 4 ft high, with 2 uprights equally spaced in between. I know this may be difficult to install due to the weight (1 entire sheet of 3/4 in birch ply, plus a 4x 8 sheet of 1/4 ply), but I will manage somehow and it is why I think it needs to be extra strong.
Comments??
Comments??
