Log Slice Drying
  • emjr
    • 21
    Log Slice Drying
    Hi.
    You'll no doubt notice that I'm mostly a lurker here; everyone else seems much better informed. I'm still in the skills-building stage. My latest project (for the wife) involves using crosscut slices of logs of about 15"-18" diameter and 1.5"-2" thick. My questions are as follows:
    1. I may have access to some trunks that have been felled for awhile and kept off the ground. Can anyone cite a source that would guide me in determining how long they'll have had to be down to have a chance of being dry? (I may be able to borrow a moisture meter, but is it worth testing logs that are less than, say, 5 years old?)
    2. If all I can find is freshly-cut timber (last winter), is there any way to accelerate drying without promoting huge checks in the slices?
    3. If I soak the slices in PEG (which I've never used, but have read about here and in other places), how much time does that add to the drying?
    4. Wife has expressed her fondest wish as being for birch, if available. Does birch in slices resist checking any better than, say, oak or maple or cherry?
    I should add that these slices are destined to remain flat, they're not for turning, so the thickness won't be reduced by much as I work them.
    I appreciate any information you can point me to.
    1. I would use a moisture meter. open air drying time is greatly affected by environmental conditions. Wood dries faster in AZ than here.
    2. The only way I know to promote drying is a kiln. There are plans out ther for a home made solar kiln. However I would think any acceleration of the drying will cause more checking, not less. The ends of cross cuts for turning blanks are sealed to prevent checking.
    cross cut sections of logs are much weaker than sections cut along the grain. for whatever you are building plan for support under it to keep the crosscut from cracking.
      A good source of info I ran across recently is:
      http://www.amazon.com/Wood-How-Dry-F.../dp/091880454X
      I got it off of bookcloseouts.com, but it's no longer listed.
      This one looked intresting:
      http://www.bookcloseouts.com/default...B&Rt=14&Nty1=1
      • emjr
        • 21
        Thank you both--good information! I'll keep in mind especially the note about supporting the crosscuts.
        EM
        • ironhat
          • 2553
          I don't know if you are still monitoring this but there's a bunch of info here.
          Best of luck!
          Blessings,
          Chiz
