Waterproof finish
  • dlminehart
    • 1829
    • San Jose, CA, USA.
    Waterproof finish
    I have an oak frame around my bathroom's jacuzzi. At the area near the faucets, years of water drips had damaged the finish. I sanded it down and refinished with a few coats of varathane. Only a couple months later, it looks worse than ever.
    What's a good waterproof clear finish to use in such a spot, that frequently has a few standing water drops?
    - David
  • Hellrazor
    • 2091
    • Abyss, PA
    • Ridgid R4512
    I use marine polyurethane..
      I finished the top on a bar I did over a year ago with this stuff.
      http://www.woodcraft.com/product.asp...2&FamilyID=751
      Even with the abuse of alcohol spills, coasters not mbeing used, etc., it still shows no signs of wear.
      • scmhogg
        • 1839
        • Simi Valley, CA, USA.
        After you remove the old finish you have to let the wood dry thoroughly. Adding heat or a de-humidifier will help speed the process. You might ask a boat refinisher how they insure the wood is dry before they apply a new finish.
        Steve
          I would sand and prep for a new finish and use Parks Pro Finisher, available at HD. It can be catalyzed and is recommended for flooring, also pretty darn good for a furniture finish. IMO, equal to if not better than OB poly, or NC lacquer for durability.
          It's water based, quick dry, and no stink.
          • RayintheUK
            • 1792
            Rustins Two-Part Plastic Finish - unbeatable!
            Ray.
            Did I offend you? Click here.
