Had originally planned on using Walnut ply with edgebanding for the top but am now thinking about resawing some Walnut at around 1/4 inch thick then through the planer for around 1/8"x 4" and glueing to a plywood base. Am I headed toward problems? Can this be done with just glue and a roller?
Thanks
Steve
Thanks
Steve
) if you try to use only a roller. A vacuum press or a bunch of clamps and cauls is whats typically required. If you do go this way you should veneer both surfaces to keep the piece balanced.
