I'm refinishing an ash bunk bed. It was originally finished with catalyzed lacquer. I'm using Resisthane Plus, sprayed on using my HP HVLP sprayer. I'd sanded the finish off the wood, then used a refinishing solvent from HD (called "Refinisher") that specified lacquer among its target finishes. I soaked a terrycloth pad with the solvent, rubbed it into the finish to soften, lifted with another pad. Finally, I wiped everything clean with mineral spirits and waited overnight to apply the Resisthane.
I'm finding that the Resisthane seems not to adhere as well as I'd expect. In places where my spraying was a little heavy and droplets formed, if I sand the drop a little too much and get down to the wood, the surrounding edges of the finish seem to lift much easier than I'd expect. If I use a ROS on such spots, small flakes of finish sometimes come off.
Any ideas? Is this normal? Did I not do a thorough enough job removing all traces of the catalyzed lacquer? Did the mineral spirits leave a residue that Resisthane dislikes? Ought I to have diluted the Resisthane with some water? (it took 15 seconds to empty the viscosity cup, the manual says 8-20 seconds is good, and someone online reported good results with 15 seconds.) Will I need to remove this coat of Resisthane and redo the solvent finish remover?
