I have a dresser satin finished with catalyzed lacquer, with some worn spots on top near the front where wet glasses were set. Looks almost like the lacquer is gone in a circular pattern.
I'd rather not refinish the entire top for a 3"x3" area. I'm wondering whether I can use a lacquer thinner on the general area (say 6"x6") to dissolve the finish, then spread it around so the entire area is covered, albeit a little less thickly. I'd then use very fine sandpaper to even out the surface to match the surrounding untouched area. (Ideally!)
Or, does dissolving the finish somehow change it chemically, so it won't harden again? Or so it won't sand to the same reflectivity?
