I have milled up and shaped all the parts necessary for 20 raised panel shutters. These are built from PT Pine. I will prime, then paint.
Question: Many mentions of making sure the panels are loose in the rails and stiles to allow for movement. My question is how loose? And also should the panel itself be shorter and narrower to allow for up, down, left, right movement? Or should the actual thickness of the board be loose fitting within the grooves? Or maybe both?
The grooves routed in the rails and stiles are about .325". Should the panel be about .125" less? I realize the panel should not be glued, but if it's shorter and narrower, won't it slide around a bit?
Any help would be great.
