I am building a table and am using mortise and tenons for the legs and apron. I always see haunches used and referred to. I understand what they are, I just don't understand why they are needed. I was just going to use stub tenons and mortises. Do I need the haunch for anything?
Haunch?
A haunched tenon isn't necessarily a stronger joint especially if it isn't well fitted. They are used primarily for alignment purposes to keep the parts from becoming uneven on the face side, and keep the joint from twisting. Misalignment of a regular M&T would be the result if it were an ill fitting joint to begin with, allowing the shoulder to move.
There are various shapes that can be done to create the haunch, and could add some strength because of an added gluing angle or surface not in the same perspective as the main part of the mortise, and acts like a key. To get a good fit may benefit the joint, but not getting a good fit is easy to do as you can't see or feel the mating surfaces while test fitting.
