I'm in the late planning stages for some base cabinetry for my basement shop, and not sure if I'm on the right track.
I'm planning a pair of 30" wide cabinets, with a 24" gap between the two to allow a spot for me to sit down to work and/or eventually plug in another 24" cabinet if I find the need. I'd like to run an 8' countertop over the top of these - leaving a 6" overhang over each end.
So, assuming I go with any of the following materials, should I expect to see any problems with sagging countertops across the 24" gap or the 6" overhangs?
- Laminate Counter top (I'm assuming no here, but not sure I want to go to this expense)
- 2 layers of MDF with hardwood edging (probably a 1/4" hardboard insert, should I go with this method
- Some alternative you'd suggest?
