When you make a project sometimes you won't find a putty that matches your wood color or species. I solved this problem by making my own putty. I collect my sanding dust from my PC RO sander, place it in an empty baby food glass bottle and mix it with denatured alcohol. Mix it to yes you guessed it wood putty consistency. Whenever the putty dires up in the bottle, just add more denatured alcohol. It'll take stains better than commercial putty.
I've also mixed the wood dust with 5 min. clear epoxy to fill larger defects. If it's a deep defect/knot hole, apply the epoxy in layers, do not fill it up in one application.
To cover up the puttied or epoxy area after final sanding or 1st sealing coat of finish: I use brown, black or orange colored sharpie pens to make it look like a knot or darker colored wood grain. It takes practice to blend it in with the wood grain but, after the last coat of finish, most people won't notice it, only you would know.
