1st project with the bt3000. Cut rails and stiles for new shaker cabinet doors.
Using a 6" dado stack to groove 1/4" for plywood panels. My question is when I setup dado stack for 1/4" cut there seems to be a little to much gap where panel goes into groove. When I remove one of the cutters it makes a 1/8" groove which is too small and requires a couple more passes through the saw. (the gappage is between 1/16 and 1/8)
Do I want the extra gap between plywood panel and groove slot? and use space balls? or do I want a more snug fit? If I go back to just using one blade and make more passes then it kind of defeats the purpose of buying the dado stack for a 1/4" groove. Although when I go to make tenons on the rails I'm sure they will go much quicker with dado stack so I will probably keep the set.
Working with Oak purchased from local cabinet shop which he ripped into 2.75 widths and ran through the jointer for me. (nice guy)
Oh, and no router (in-laws was only 1/4" collet and wasn't doing the job.
