finally done cutting dovetails...
    I was determined to finish dovetailing the drawer boxes tonight, probably a mistake considering the little sleep I'll have for tomorrow. Anyway, I broke out the Leigh jig a couple of days ago, it's been over a year since I've used it, so I played a bit first.
    Here's a sample joint that I cut, deciding upon the spacing I liked.
    And finally, here are all of the drawer boxes for the hot wall. We're doing 1/2 at a time, so I get to take a break from dovetails for a while. Thankfully I have the VRS, it was messy with it, would have been horrible without it.
    Thanks for looking,
  • jking
    • 972
    • Des Moines, IA.
    It's looking good. A success that you got them done as late as you were up. I would have ended up doing something stupid like accidentally cutting dovetails in the top of a drawer.
      Looks good, Keith. Out of curiosity, how long did it take to do the cutting vs. setup time?
        Good question JR, really it was mostly the cutting. The Leigh jig is pretty efficient overall, if you do things in batches. These represent drawers from 2 base cabinets, each cabinet has a 5", 6", and 8" drawer. (actual drawer side size, not opening size).
        I surfaced everything together, which easily took as long as cutting the dovetails, as I don't have a stop for 5/8" I went to about 1/32" oversize and drum sanded to final dimension.
        Then I had 3 setups, one each for 5", 6", and 8". They are somewhat related mathematically, so it wasn't too bad to do the setups, just about marking a board and moving the pins around.
        I have yet to buy a 2nd guide bushing, which I really should do, as I have 2 routers, that would have made the job a lot faster. Most of my time was spent changing bits and resetting protrusions, in terms of setup. A lot of cutting, of course.
          Nice job Keith,
          Repetative parts are rather boring but doing the setup once is certainly preferable to doing each one indivdually.
