Hi Folks,
I'm in the process of dialing in the final dimensions on birch plywood 3/4" panels that will be used for a shop cabinet and was wondering if there was a rule of thumb for determining the go-no-go for trimming a wide panel? For example, using a combo blade (Hitachi 40 tooth), I'd like to use the rip fence to square and trim a 38-1/2" x 28-1/2" panel down to 38x28 - figure about 1/4 inch will be removed from each side. Normally I try to avoid using the short edge against the rip fence, but this project is too big for the SMT and I don't yet have a miter slot that could be used for a nice panel sled. A buddy told me as long as the wood held against the fence is wider than the blade it's ok, but I wanted to bounce this off of the folks here. Please let me know your thoughts on this.
Best Regards,
Saugus, CA
Best Regards,
Saugus, CA
