By the time you get ready to spray your finish, the last thing you need is to have some foreign matter spit out on your work. You might already have a filter on your compressor (not totally useless, but close), and think you're getting clean air out of the gun. Or, you may have a wall mount filter/regulator that the hose attaches to.
Here's a suggestion that may be of some help. I mount right on the gun one of these little jewels called a "bulb filter", or a "final filter":
That little bugger will catch pretty much of anything before it gets to the gun. It will improve the finish. In addition to that, I also add a small air regulator to the final filter, similar to this:
I find having a regulator right on the gun can control the air much more accurately than a distant one.
