When I started my kitchen cabinet project back in the spring, we decided on hard maple because LOML wanted to stay away from what we have now (oak,) but she also didn't want to go too dark (which was fine by me, because I didn't want to pay for cherry.)
I need to buy the lumber for the ff's soon, so I picked up several different colors of stain, and using blocks of maple that I'd planed and sanded, we tried out a number of different finishes. Lo and behold, the consensus pick is pretty dark - two coats of Bartley jet mahogany over one coat of their georgian cherry (or perhaps just 2-3 coats of jet mahogany.) Go figure!
Now I'm thinking, why bother using hard maple if I'm just going to cover it with dark stain? My first thought was to switch to birch, but why not cherry? It's already darker, and it's reputedly easier to work with. As for the cost issue, I'll likely be buying my hardwood from Hearne Hardwoods in Oxford PA, where the cost differential is only 50 cents/bf. ($5.00 vs. $4.50.)
Problem is, I already have three wall cab carcasses constructed that have exposed end panels made from maple ply. However, I was already regretting having not made raised panel ends for them. I was thinking of constructing new end panels, and attaching them over the existing plywood ones before the face frames go on. (The 2" wide stile would be more than wide enough to cover the edges of the double side panels.) If I change lumber, I can just make them out of cherry instead of maple. Any problems with that?
One more "If only I'd thought of that"... I wish I had built the cabinet above the microwave deeper than 12", to make it flush with the front of the oven. I suppose I could just bump it out when I install it, and cover the exposed portions of the end panels with more plywood, and cherry veneer. Any other ideas?
I better get back to work. The longer it takes, the more changes I'm going to have to make!
