water based finish
  • jaspast
    • 15
    • San Pedro, CA
    water based finish
    I am going to make some small projects for Christmas, and I have a finish question. If I use some 23 gauge pins, will I have a problem with a water-based finish? I don't want them to rust later on.
    Thanks
  • herb fellows
    • New York City
    You can get stainless steel 23 gauge pinners. I don't recall where I saw it, but I probaly googled it. You could probably find some coated nails also that might work, but I would spring for the stainless. No sense ruining your beautiful work over 20 cents a box.
      Most of the pin nails, brads, and staples are galvanized. Seating the fastener and filling the hole, or finishing over will seal. I've never had a rust problem with waterbased finish over a fastener on interior furniture.
      • jaspast
        • 15
        • San Pedro, CA
        Thanks
        Great. Thanks for the answers. I was concerned about the finish itself causing rust, but it sounds like this won't be a major concern.
        This is one of my first woodworking projects, and while I'm not in a hurry yet, if I don't get moving I will be. I have to have it finished by Sunday so I can fly home for Christmas with it.
        • Tom Slick
          • 2913
          • Paso Robles, Calif, USA.
          • sears BT3 clone
          once the finish dries there is no water left to cause rust. the finish itself isn't corrosive.
