Going to frame a 5' x 2' mirror (heavy) to hang on wall. Was going to use my rail & stile bit set that I also use for cabinet doors- so the mirror is basically a giant panel set into a frame. Planning on about 2.5"-3" wide rails and stiles, and the assembly would be hung on the wall by the top rail.
I don't trust just the glue joint with the rail stub tennon to hold this, given the downward sheer stress from the heavy mirror. Is there any reason I couldn't reinforce each rail-stile joint with 2 pocket screws?
Would drill the pocket screw holes first at the ends of each rail, then cut the sticking profiles afterwards. Then I'd clamp and glue up square, and once glue sets I'd drive in the pocket screws for reinforcement. They'll wind up going through the stub tennon I think.
Any reason not to do this?
