For the pantry cabinet I'm making for LOML's kitchen I needed to veneer one side of the cabinet that will show since I didn't want to make that side out of solid ash. I looked around and didn't find what I was looking for so I decided to take on trying to make my own on the bandsaw.
Quick trip to get a 3/4 3TPI Timberwolf blade and I was ready to try it. Had to setup a fence which didn't take long and adjust for drift and I was ready to cut a 3/16 veneer. At first it was a bear and very hard then it dawned on me I had the blade too slow and it was loading up. Made that adjustment and it started cutting beautifully with that nice singing sound and no binding.
I've got a nice stack of 6' long by 5 1/4" wide by 3/16 rough cut veneer. Is this too thin to face on the jointer before I run it through the planer to get to 1/16?
The wife mentioned that it looks like I'll need a vacuum bag press to do this job so I should start pricing one. Thanks to David Marks who showed her on Woodworks how much easier it is if you have one of those.
Might as well do the inside in the ash also but maybe I can find some cheaper birch in a large sheet for that.
