Is there a general consensus on the strength of a 90* butt joint reinforced with these three common means? I've read conflicting reports googling it.
When using high quality modern glues, are each of the 3 'good enough' for reinforcing butt joints in furnature frames and tables construction?
For purposes of discussion, assume fluted dowels like these: http://www.rockler.com/product.cfm?p...&filter=dowels
with 2-3 per joint.
Assume 2 #20 biscuits per joint.
For Loose tenons, assume a 3/8" x 1.5" long x 1" deep mortice on each side of joint and a hardwood loose tenon of same species as wood being joined.
with 2-3 per joint.
