In trimming the top of a small countertop, my son (I wouldn't do this! LOL) pushed the router too hard into the edge of the countertop and took off some of the plastic laminate (PL) of the vertical edge. So, it's repair time.
Here is my plan: Using heat gun, remove the PL from the edge. Clean the contact cement from the 1-1/2-inch wooden edge with lacquer thinner on a rag, all the while being careful not to get the thinner in the contact cement holding the top down. Hand sand the edge to get rid of any stubborn glue.
Then I think I think I have two choices:
1. Trim the edge of 2" piece of PL dead straight (using a router carbide bit and an offset fence), apply glue to the edge and PL piece, jam the PL piece up tight into the overhang of the top PL piece (trimmed during the mistake), J roller down, and then trim the other three sides of the PL edge. Then apply a 15-degree bevel to all four sides of the top.
or
2. Trim the top flush with the edge, apply glue to the wooden edge and PL edge piece, glue the two pieces together, J roller, trim all four sides. Then apply a 15-degree bevel to all four sides of the top. I know this side of the top will look sightly different from the other three sides of the top, but it seem to me to have higher chance for success.
Which way do you think I should proceed? Or is there a better way?
Thanks,
or
Thanks,
