Best router bit diameter for trimming laminate
  • bmuir
    • Jul 2006
    • 63
    • Rochester Hills, MI
    What is the best diameter flush trim bit for trimming plastic laminate?
    Thanks,
    So little time, so much wood!
  • Sawatzky
    • 359
    • CA
    mine is a 1/2 inch with a 1/4 inch shank. Just used it yesterday and it works fine.
      A three flute 1/2", with 1/4" shank gives an excellent cut...very smooth. For the small trimmer routers, with less power, a 3/8" diameter, cuts very easy, takes out less material, and gets further into the corner.
      For the no bearing bits (panel pilot), these work very well.
