I have a few questions about magnets that could be used as door/drawer catches.
And here's a little more background about what I'm trying to do, so maybe there's a better approach overall...
I am thinking of using ~24 small magnets to keep 12 drawers from sliding open when the case they're sitting in tilts slightly. The runners on these drawers have very little friction and no "bump" at the end to keep them closed. The net effect is that when one or two drawers are opened at the same time there is enough forward tilt of the case that the rest come sliding open. This was not a problem for my wife and me, but with the baby crawling and pulling things open this was a problem.
I have secured the units (hand-me-downs, fairly cheap flatpacks I'm sure) to the wall so the whole thing can't tip and crush the little guy, but there's enough give with the thick carpet and pad that drawers will still open on their own which is a nuisance and still potential safety hazard. The loads in the drawers are light (baby clothes/paraphernalia)
I considered trying to shorten the back slightly but this might look odd as the molding would then appear to be slanted.
I also considered trying to add leveling feet to slightly raise the front but a quick experiment with some washers seemed to concentrate the weight more so even with four "feet" the front didn't really sit any higher or depress less when the drawers were opened.
New homemade furniture with a more steady design would be great, but that's not in the cards in the near future. Any insight about the best approach in the meantime?
Thanks,
Kristofor.
- Is there a table that lists standard attractive forces for magnets of a given composition/size? Maybe just a rule of thumb for a given diameter/thickness? (I'm obviously not googling for the right terms on this one)
- What is considered a "standard" or desirable level of additional pull/resistance for a magnetically latched door/drawer (I know this will depend on the mass of the door/drawer involved and may need some tweaking, but should I start at 3% or 30% of the component I'm trying to control)
- Are there any preferred suppliers or ones to stay away from at all cost? Both Rockler and Woodcraft have these locally, is there any real difference from one supplier to another? Anything heads and shoulders better online (cost or selection)?
Thanks,
Kristofor.
