I've heard this said many times by some of our more knowledgable partners on here. I've also found some articles on the web.
But I still run into problems when making final router cuts especially in edge profiles, stiles and raise panel. This is mainly with maple. With pine and oak it's easier to determine the direction of the grain.
With stile routing for example, it's after you start to cut you notice that it's going against the grain and your left with two options, sanding or discarding. You can't flip it around to cut in the opposite direction.
One other consideration I imagine would be to make the final cut about a 1/64" shave. I'm not sure this would help.
Test cutting sample on maple to determine grain direction can be a costly sacrifice.
So what am I doing wrong? How do you get around this?
Howie
Howie
