I kept threatening to make one but always had something else to work on...so a couple nights ago I put everything aside and built a small 24x24 sled to see if it was worth building a larger one. I wasn't real happy with how it moved in the table slot until I remembered to wax the guide, smooth as silk after that.
Fast forward to a couple hours ago when I had to cut some pieces of padauk for the base of LOML's table I'm making. Ran one end through the saw on the sled to try it out, dead square. Marked the other end at 24" and lined up the pencil mark with the cut line, all are exactly 24" long and square.
I gotta make a bigger one now.
Remaining to do, add a lexan guard over the blade, add something where the blade exits the sled to avoid naked blade syndrome.
Live and learn.
Remaining to do, add a lexan guard over the blade, add something where the blade exits the sled to avoid naked blade syndrome.Live and learn.
