Raise panel door question
  • newood2
    • 600
    • Brooklyn, NY.
    I'm making my first raised panel door, 4 in all, using maple. The panels will be 21"H X 7.5"W.
    Which would be a better idea for the width of 7.5"?
    1- Using 1 X 6 maple(5.5" width) and edge join a 2" piece.
    2- Edge joining 3 pieces of 2.5"
    I'm concern about panel warping.
    Howie
    It should not matter. I would use 2 pieces because it is easier but either way should work fine. If the wood is dry, it should not warp significantly.
    I finish the panel and the inside edge of raised panel doors prior to glueup. I do not put finish on the joint, of course. I like to do this because I have seen doors that shrunk a little and exposed an unfinished edge of the panel. I do not like that look.
    After glueup, I use a random orbit sander to flush the joint and then I finish the frame. I put another coat on everything when I am putting the last coat on the frame.
      Howie,
      For look of the grain, I'd probably shy away from a 5.5in+2in option. If 8in width is not available, I'd probably go for an edge-joint of two pieces cut to 3.75in - that may create more cut-offs than you'd prefer, but allows for best grain-mirroring or matching. Three pieces are do-able, but not sure how the three joints will reveal after cutting with the panel raiser.
      If you haven't already seen the tips on panel raising here, I'd do a search for some. I recommend some of the following -
      1. USE THE FENCE on your router table. It may be tempting to use the pin and try to move the panel up to the bearing on the raising bit - don't do it. If you need to build an auxiliary sacrificial fence, do so. Check alignment of the fence with the front of the bearing on the bit to ensure the panel won't be bumped away from the fence by a protruding bearing. Use a rule or straightedge to check bearing is flush with face of fence.
      2. Use hold-downs or featherboards clamped to the fence (I use some like these - http://www.woodcraft.com/family.aspx?familyid=3943 - stiff side down) to maintain uniformity of cut depth - the moving bit will want to push the panel upward.
      3. Make your cuts in several passes to reach your final cut depth, starting with the bit set low, and gradually raising the bit between 1/16 and 1/8 per pass, until last two passes, go by 1/32nds (should help remove, or prevent, any burning by the bit.) Cut all sides on all panels before changing the bit height.
      4. On each panel, cut the ends across the grain first, using a backer block to prevent tear-out. Then cut the sides along the grain (and still recommend backer block.)
      5. Respect the cutting area of the bit. That's alot of exposed carbide with serious momentum.
      6. I recommend some good under-table DC, because that's where most of the debri will be heading.
      If you haven't already, run some test cuts on some extra (apprpriately wide) material. It'll give you a good idea of what kind of feed rate you'll want for cutting your workpiece.
      • newood2
        • 600
        • Brooklyn, NY.
        Thank you guys
