An article in a recent FWW extolled the benefits of Hammer Veneering. Since I already have an old cast iron double glue pot and a supply of hide glue, I decided to try it. I use an old steam iron, dry, upside down in a vise, as my heat source.
I made a jury rigged hammer from a brick/masonry chisel. I was really pleased at how easy it was. Now, mind you, I was only veneering pieces less than 18" X 18".
So. . . I decided to make a proper Veneer Hammer. I used a block of Blackwood for the head and Ash for the handle. Blackwood is as hard and dense as true Ebony. The Ash looks like a baseball bat. The blade is 1/8" brass bar stock.
I turned the Ash handle on the large side. I have big hands and the size makes it comfortable and easy to apply pressure. It is finished with a few coats of shellac.
The head is sanded smooth to 600 grit with several coats of Renaissance Wax. Blackwood is one of those nightmare woods to finish. I tried poly, which stayed tacky. I cleaned it off and put two coats of dewaxed shellac. Even the shellac didn't flow well. I put poly on top of the shellac and it was still tacky three days later. Hence the wax only finish.
Steve
Steve
